Re: 4pi flat pack, Rhino Line [message #92301 is a reply to message #92299] Wed, 09 September 2020 14:15 Go to previous messageGo to next message
Wayne Parham wrote on Wed, 09 September 2020 14:09
Looks great! You inserted your T-Nuts exactly the same way I do - With a dab of glue to hold 'em in.
Thanks for the build thread!
Glad it's Wayne approved! Now I await the Pi 4 kit to document each and every step as a build guide. Wink
Re: 4pi flat pack, Rhino Line [message #92302 is a reply to message #92301] Wed, 09 September 2020 17:22 Go to previous messageGo to next message
I'm anxious to see Sean's build too. I'll bet he'd be happy to get the same look as you did on your subs. You really did a good job and I'm sure he appreciated the tips.
Re: 4pi flat pack, Rhino Line [message #92303 is a reply to message #92302] Wed, 09 September 2020 17:38 Go to previous messageGo to next message
Wayne Parham wrote on Wed, 09 September 2020 17:22
Guess you missed my intent Laughing
I do look forward to his build though.
Re: 4pi flat pack, Rhino Line [message #92304 is a reply to message #92303] Wed, 09 September 2020 21:27 Go to previous messageGo to next message
rage889 is currently offline  rage889
I'm impressed you made that Duratex look so good!
I was tempted to go that route - but laziness prevailed and I dropped the assembled cabs off to the local Rhino liner today. I'm guessing cost will be about Double the diy route - hopefully the results are as good as what you did!
I like the choice of neutrik connector as well - that is also a tempting option here.
Re: 4pi flat pack, Rhino Line [message #92305 is a reply to message #92304] Wed, 09 September 2020 21:30 Go to previous messageGo to next message
rage889 wrote on Wed, 09 September 2020 21:27
Go get them back! You'll need a half gallon of duratex and one roller. The cleanup is so easy with Duratex it's silly. The Neutrik is just nice and simple without any wires falling out ever. I like them when possible.
If you really are going to add the Neutrik, I really suggest you do it before paint though. It would really suck to have an "oops" on a finished cabinet.
Re: 4pi flat pack, Rhino Line [message #92323 is a reply to message #92291] Tue, 15 September 2020 16:05 Go to previous messageGo to next message
tubino is currently offline  tubino
Thanks for posting these details! It's very useful for me. Did you use 10-32 for the t-nuts, or 1/4" x 20?
Re: 4pi flat pack, Rhino Line [message #92325 is a reply to message #92323] Tue, 15 September 2020 16:14 Go to previous messageGo to next message
tubino wrote on Tue, 15 September 2020 16:05
1/4"-20 Tee Nuts for my driver. However, if you are using a small Waveguide or driver you can use 10-32 without an issue. Overkill is usually good; however, the bolt still needs to go through the trim ring. Wink
Re: 4pi flat pack, Rhino Line [message #92326 is a reply to message #92257] Tue, 15 September 2020 16:59 Go to previous messageGo to next message
Wayne - what size bolts/screws do I need for the T-nuts installed in your flat pack cabinets?
Here are a few progress photos:
/forum/index.php?t=getfile&id=2637&private=0
/forum/index.php?t=getfile&id=2638&private=0
/forum/index.php?t=getfile&id=2639&private=0
/forum/index.php?t=getfile&id=2640&private=0
/forum/index.php?t=getfile&id=2641&private=0
  • Attachment: 621527792.jpg
    (Size: 157.69KB, Downloaded 739 times)
  • Attachment: 621527801.jpg
    (Size: 190.20KB, Downloaded 731 times)
  • Attachment: IMG_2373.jpg
    (Size: 126.45KB, Downloaded 783 times)
  • Attachment: IMG_2395.jpg
    (Size: 155.06KB, Downloaded 766 times)
  • Attachment: IMG_2396.jpg
    (Size: 112.30KB, Downloaded 842 times)
Re: 4pi flat pack, Rhino Line [message #92330 is a reply to message #92326] Tue, 15 September 2020 22:32 Go to previous messageGo to next message
Wow! Those look great!
Use 10-32 screws. Black oxide button head screws look really nice.
Re: 4pi flat pack, Rhino Line [message #92332 is a reply to message #92257] Wed, 16 September 2020 06:52 Go to previous message
Black usually isn't my favorite speaker finish but those look fantastic. The texture really make it pop.
Previous Topic: Pi 8 plans
Current Time: Tue Jul 15 10:22:37 CDT 2025
