Home » Sponsored » Pi Speakers » 4Pi Xover Optimized for SET Amps
4Pi Xover Optimized for SET Amps [message #92068] Tue, 30 June 2020 11:56 Go to next message
slhijb is currently offline  slhijb
A quick question for Wayne. I'm building the 4Pi's and powering them with a 2A3 SET amp. I was reading some older forum posts and came across one where a member adjusted his 4Pi Xover for SET amps.
https://audioroundtable.com/forum/index.php?t=msg&goto=63306
In the post you mention,
"For SET amps, you can reduce the number of resistors... There is no harm having them, but as long as the power stays low, no heat is generated, and no damage to the resistors even if you only use one per R1/R2 leg."
I purchased the 4Pi Xovers pre-assembled and am wondering if you can recommend some modifications that will optimize them for a flea power 3.5 watt per channel amplifier? The Xovers are built for the B&C DE250 & JBL 2226HPL, 8ohms driver combination. I am handy with a soldering iron. Hope you can help. Thanks!
Re: 4Pi Xover Optimized for SET Amps [message #92069 is a reply to message #92068] Tue, 30 June 2020 14:30 Go to previous messageGo to next message
What you have now is better than what we were discussing on the thread you referenced. That thread discussed de-rating the resistors because the amplifier power level was so low. It was a convenience thing, I suspect.
One can always have more thermal capacity than is required. The only problem is not having enough thermal capacity, which causes parameter shifts and eventual failure. But there is no penalty for having too much thermal capacity. The resistors will all just run nice and cool. Cool
Re: 4Pi Xover Optimized for SET Amps [message #92070 is a reply to message #92068] Wed, 01 July 2020 05:34 Go to previous message
Thanks Wayne. Got it.
Previous Topic: 2 pi & 2 pi tower plans
Next Topic: Three and Four Pi Plans Request
Current Time: Tue Jun 15 20:20:41 CDT 2021
