Home » Audio » Source » Amp settings
Amp settings [message #12834] Mon, 06 March 2006 17:01 Go to next message
Pablo is currently offline  Pablo
Got a new amp, you can select various phono setting. If I have a Phono cartridge which has an output of 5mv and a imput load of 47K, would setting my amp to a sensitivity of 6mv and a 50K ohm imput load (which are the closest possible setting) be close enough? The total possible settings are .5/3/6 mv and 30/50 and 100k loads. How much are cartridge specs changed my the turntable? I'm getting a Sensui Au-20000, and looking to use a Technics 1200 MKII with it. Any ideas for cartridges?
Re: Amp settings [message #12836 is a reply to message #12834] Mon, 06 March 2006 22:12 Go to previous messageGo to next message
That load setting will be just fine.
Re: Amp settings [message #12837 is a reply to message #12836] Mon, 06 March 2006 22:19 Go to previous message
Thanks!
Previous Topic: turntable upgrade?
Next Topic: why won't my turntable play clear vinyl?
Current Time: Sun Nov 29 18:27:27 CST 2026
