Home » Audio » Source » Bent records
Re: Bent records [message #92543 is a reply to message #91839] Sat, 31 October 2020 12:47 Go to previous messageGo to next message
Rusty, sorry it's taken me so long to respond, but no they weren't thin records. It was incredibly bent and I doubt anything would've fixed it. I'd like to know how it got that way to be honest!
Remi, you should try it and let us know which method worked best for you. Just start with the records that you care the least about. I had a lot of fun doing it.
Re: Bent records [message #92548 is a reply to message #91839] Sun, 01 November 2020 17:36 Go to previous messageGo to next message
Concorde is currently offline  Concorde
Is anyone considering groove distortion? I see a lot of tips on how to flatten a warped vinyl, but when the vinyl itself is warped, so are the grooves. When it gets flattened, do the grooves just pop back into place like nothing has happened?
Re: Bent records [message #92550 is a reply to message #92548] Sun, 01 November 2020 20:38 Go to previous messageGo to next message
Hi, A good question. I don't know. If the fixing process makes the LP out of round that will cause problems as the sound will waver and many cartridges might have problems following the groves.
Re: Bent records [message #92611 is a reply to message #92548] Sat, 14 November 2020 17:39 Go to previous message
Concorde wrote on Sun, 01 November 2020 17:36
It's definitely not perfect, but it's a matter of losing one or two songs rather than the whole record. You take what you can get. It might work better in one of those machines that are designed for this issue.
Previous Topic: Create your own
Next Topic: Oiling Turntable Bearings
Current Time: Tue Jul 15 11:00:21 CDT 2025
