Home » Audio » Source » Elac Miracord 50 H II
Elac Miracord 50 H II [message #12811] Tue, 21 February 2006 12:56 Go to next message
draudio2u is currently offline  draudio2u
Greetings,
I have an ELAC 50 H II that I am trying to get working correctly. The problem is the automatic drop into the play position. The arm moves into place, the release lever moves down and then two seconds later, the arm drops by weight of gravity, bouncing the needle on the LP and into the first track. Is there not a counter spring to lower the arm slowly? Anyone have advice?
Thank you.
Re: Elac Miracord 50 H II [message #12812 is a reply to message #12811] Tue, 21 February 2006 13:08 Go to previous messageGo to next message
Look for a hydraulic damper. The damper is probably shot so replace it.
Re: Elac Miracord 50 H II [message #12813 is a reply to message #12812] Tue, 21 February 2006 13:18 Go to previous message
Would this be inside the arms center spindle? Not the sponge on which it gets lifted?
Previous Topic: broken needle
Next Topic: How important is a pre-amp if your amp has volume pots?
Current Time: Fri May 10 10:30:56 CDT 2024
