Home » Audio » Room Acoustics » Soundproofing a room
Soundproofing a room [message #91549] Sat, 14 March 2020 00:18 Go to next message
Most of us are often concerned with dealing with the energy within our studios while forgetting sound generated from outside a room, which causes vibration traveling through solid material. How best can we ward off external interference?
Re: Soundproofing a room [message #91589 is a reply to message #91549] Thu, 19 March 2020 20:43 Go to previous messageGo to next message
I used that have that problem with a couple of my wireless speakers and I tried everything from creating a floating barrier between my wall and the neighbors wall (these were apartments) to anchoring the speakers in different positions. What actually helped was simply increasing the strength of the signal to the wireless receiver and moving the receiver slightly closer to the transmitter (moving them too close together creates other problems). It's not exactly soundproof, but the audio sounds much better.
Re: Soundproofing a room [message #92168 is a reply to message #91549] Sun, 16 August 2020 21:24 Go to previous message
Vaiger is currently offline  Vaiger
Here's one solution:
https://images.unsplash.com/photo-1508690305591-b421948d9d3b?ixlib=rb-1.2.1&ixid=eyJhcHBfaWQiOjEyMDd9&auto=format&fit=crop&w=500&q=60
If that's not an option, use nature......trees, shrubs, etc.....as a natural buffer. Make sure the structure is as airtight as possible and add special insulator panels made with soundproofing in mind where possible.
Previous Topic: Sound masking vs sound absorption
Next Topic: Quick and Dirty acoustic treatment
Current Time: Thu Oct 29 05:13:37 CDT 2026
