| 3 pi updates [message #91523] |
Thu, 05 March 2020 08:10  |
Barryso
Messages: 226 Registered: May 2009
Master |
You mentioned you're bringing the 3 pi speakers to the LSAF with the B&C woofers. You've probably mentioned how the new woofers sounds elsewhere but I've missed it.
How would you describe the changes to the 3 pi with the B&C woofer? In the 4 pi with the JBL woofer it doesn't dig down as deep as the Eminence driver but it has the shorting ring and the purty midrange. How does the B&C compare to the JBL 2226 and/or to the older versions of the 3 pi?
