Home » Sponsored » Pi Speakers » MiniDSP (Active Line Level Crossover)
MiniDSP [message #91225] Wed, 27 November 2019 14:15 Go to next message
leonski is currently offline  leonski
I'm curious about others success or problems using MiniDSP crossovers. I am Particularly Interested in the use
of FIR filters. I was reading around here....and can't FIND it again, that steep slope analogue filters induce lots of phase
shift. This is a known issue with all filters which 'precess' at 90degrees per 'order'.
FIR filters have NO phase shift thru the passband. But they do require a bit of computing power, which is part of even the
MiniDSP 2x4HD. The HD part is important. Software also includes several parametric adjustments per INPUT and
OUTPUT. Shelving is possible and room modes can be 'dialed in'.
If anyone has gone this route, I'd sure be curious as to results and difficulty. I'd personally start with the points and slopes
of the 'stock' crossover and go from there. But the FIR filter would be nearly a whole new ball-game.
Re: MiniDSP [message #91227 is a reply to message #91225] Wed, 27 November 2019 15:33 Go to previous message
Digital filters are awesome because of their flexibility.
In the case of loudspeakers - and particularly controlled directivity loudspeakers - you have to be careful with your choice of filters because they affect summing through the crossover region. So steep slope filters aren't necessarily your best bet. Nor are first-order filters necessarily your best bet.
In my experience, the best filter is found using a process like I describe in the link below:
And for room modes, no electrical filter is sufficient because the most sophisticated filter can only have a two-dimensional effect, whereas room modes are a three-dimensional phenomenon. The solution for room modes is flanking subs and multisubs.
Previous Topic: Just finished 4pi build need some tips
Next Topic: 4PI cabinet drawing
Current Time: Thu Apr 09 22:15:14 CDT 2020
