Home » Audio » Source » Sony Drive-belt replacement
Sony Drive-belt replacement [message #12692] Tue, 20 December 2005 03:10 Go to next message
Patrick is currently offline  Patrick
Hi all,
Can anyone advise me? I've come across an old turntable (Sony PS-LX220) with a drive belt detached. No manual with it. Any idea how to replace the belt? Do I open up the box? There's a pulley which spins when it's turned on, under the turntable itself, but as far as I can see it can't drive the turntable directly because it's not touching the side of it underneath, so it must need a belt.
If anyone has an illustration from a Sony manual on how to replace a belt, that might be the best help. Or any other suggestions?
Many thanks,
Patrick.
Re: Sony Drive-belt replacement [message #12693 is a reply to message #12692] Thu, 22 December 2005 03:45 Go to previous message
Hi
I've found out how to do it now - thankyou.
Previous Topic: best score yet at Goodwill
Next Topic: Turntable setup help needed
Current Time: Fri Nov 27 04:32:39 CST 2026
