Home » Audio » Speaker » The DE912a Arrays of Awesomeness
Re: The DE912a Arrays of Awesomeness [message #90650 is a reply to message #90647] Mon, 08 July 2019 11:46 Go to previous message
gofar99 wrote on Sat, 06 July 2019 21:55
Nice build Fred. They are bigger than my Martin Logan ESLs, but your sub is much smaller. I have used the DEQ for room correction and it will do that. But I felt in the long run it did more harm to my acoustics than it did good. The Behringer electronic crossover (set for 24 db/oct at 45HZ 2 way) is another story. It is great for separating the sound to the subs and seems invisible.
I'm ok with the DEQX, but I'll probably build a passive crossover so I can use these speakers with any integrated amp or amp/preamp combination. They are very sensitive and the woofer array presents a 10 ohm nominal load, so it should be easily driven by an EL34 or KT88 tube amp.
Another less pricey option for dsp and bi-amping would be a mini DSP processor like this.
https://www.parts-express.com/dayton-audio-dsp-408-4x8-dsp-digital-signal-processor-for-home-and-car-audio--230-500
Previous Topic: B&C 21DS115 4OH
Next Topic: Bass Knob Problem
Current Time: Fri Mar 29 08:48:40 CDT 2024
