Home » Audio » Room Acoustics » Drapes or Curtains
Drapes or Curtains [message #89165] Mon, 12 November 2018 04:56 Go to next message
Jethro is currently offline  Jethro
I know that drapes absorb more sound than curtains. What do you think about which one will help produce a better sound quality for room acoustics?
Re: Drapes or Curtains [message #89173 is a reply to message #89165] Mon, 12 November 2018 09:55 Go to previous messageGo to next message
I recently replace some thin drapes with more substantial curtains. I think it's helped with the sound quality in the room.
Re: Drapes or Curtains [message #89195 is a reply to message #89165] Tue, 13 November 2018 17:39 Go to previous messageGo to next message
I think so too. Large halls, like the theater, might be needing drapes or carpeted walls to minimize the echoing of the sound. Our rooms are not that big enough that we needed drapes to absorb the sound.
Re: Drapes or Curtains [message #95833 is a reply to message #89165] Thu, 14 July 2022 07:39 Go to previous messageGo to next message
Curry is currently offline  Curry
The difference is not substantial with drapes or curtains. I see some theatres use both. There are other considerations like the wall paneling, furniture, and flooring since everything in the room will want a share in the good distribution. There will be much more done to a room to bring in the quality of a theatre.
Re: Drapes or Curtains [message #95841 is a reply to message #95833] Fri, 15 July 2022 21:12 Go to previous messageGo to next message
Hi, It seems that the question is what do you think is not as good as it ought to be? Second what is the room like now in terms of construction (wood, brick, cement..) what is the size, shape and contents? All these things will alter the sound. I suspect that just window coverings will not do the whole job, especially if you have hard, flat surface walls. Let us know and we will see if we can come up with some ideas.
Re: Drapes or Curtains [message #99076 is a reply to message #95841] Tue, 04 November 2025 13:09 Go to previous messageGo to next message
Helen is currently offline  Helen
That’s a good question! I’ve heard that drapes do a better job since they’re usually thicker and heavier, so they absorb more sound.
Curtains can still help a little but I think drapes make a bigger difference if you’re trying to soften echoes or improve how the room sounds. I’d probably go with something heavy and lined like drapes because the lining adds weight, provides insulation, blocks light and helps them hang more formally with elegant folds, it also makes the room feel cosier and looks nicer too.
Re: Drapes or Curtains [message #99143 is a reply to message #89165] Sat, 20 December 2025 08:54 Go to previous message
Clint is currently offline  Clint
I make use of multi-layer acoustic drapes and I am so happy about the decision that I made.
Using heavy drapes also helps in reducing echo while the pleated designs improve surface area and effectiveness.
If you can afford the pleated velvet that comes in panels, then that will be very good. I used 12  panels for the 3 windows in my place and it was truly a game-changer for my listening experience. Each panel cost around $55 when I bought it last year.
Previous Topic: Concrete and Tin
Next Topic: Movable Panels
Current Time: Sat Nov 07 17:38:28 CST 2026
