Home » Audio » Speaker » Maintaining The Speaker In Good Shape
Maintaining The Speaker In Good Shape [message #89163] Mon, 12 November 2018 02:32 Go to next message
Malfoy is currently offline  Malfoy
I've read the topics here in which the speakers had problems. How do we maintain our sound system in good shape? What are the main culprits in damaging the speakers?
Re: Maintaining The Speaker In Good Shape [message #89170 is a reply to message #89163] Mon, 12 November 2018 09:27 Go to previous messageGo to next message
Excessive moisture and direct sunlight are the two biggest problems for speakers, except of course over-driving them in some way. As long as you don't push 'em too hard they'll last decades provided you take care of them.
Also, don't store them in a position where the cone faces up or down. The cones can sag after several years, especially subwoofers.
Re: Maintaining The Speaker In Good Shape [message #89226 is a reply to message #89163] Thu, 15 November 2018 08:41 Go to previous messageGo to next message
Jazzy is currently offline  Jazzy
I didn't know that there are people who positioned the speaker cones facing up or down. How do we know when we are over-driving the speakers already?
Re: Maintaining The Speaker In Good Shape [message #89229 is a reply to message #89226] Thu, 15 November 2018 08:54 Go to previous messageGo to next message
When you over-drive a speaker, it usually starts sounding very distorted.
As for the cone-up or cone-down thing, I was mostly talking about storage. If you lay speakers on their backs (cones facing up) and store them for a few years, you may find the suspension has sagged over time.
I have seen some subwoofer cabinets designed to face the woofer down though. It's an interesting design, and makes the woofer cone "invisible." But the disadvantage is that the cone weight will tend to shift it downwards, which will only get worse over time.
Re: Maintaining The Speaker In Good Shape [message #89233 is a reply to message #89163] Fri, 16 November 2018 02:28 Go to previous messageGo to next message
The face down subwoofer storage sounds interesting. Do you mean to say that using the speaker is better than storing it because the dormancy will make the cones sag?
Re: Maintaining The Speaker In Good Shape [message #89240 is a reply to message #89233] Fri, 16 November 2018 10:36 Go to previous messageGo to next message
Positioning a driver "face-up" or "face-down" can make the suspension sag over time, especially subwoofers with heavy cones and loose suspensions.
Re: Maintaining The Speaker In Good Shape [message #89259 is a reply to message #89163] Tue, 20 November 2018 08:13 Go to previous messageGo to next message
Junior is currently offline  Junior
I've noticed several old speakers having their dust covers pushed-in. What may have caused this from happening? Does it even affect the speaker output quality when the dust covers were pushed-in?
Re: Maintaining The Speaker In Good Shape [message #89261 is a reply to message #89259] Tue, 20 November 2018 08:29 Go to previous messageGo to next message
Curious fingers are usually the cause of dented voice coil covers. Something or someone has pushed them in. They do contribute to the sound in most speakers, but not subwoofers. Subs usually have a cap that's harder to dent too.
Fortunately, it's usually an inexpensive and easy fix. Take your dented speakers to a speaker repair shop and they'll replace those dented caps.
Re: Maintaining The Speaker In Good Shape [message #89274 is a reply to message #89240] Tue, 20 November 2018 18:31 Go to previous messageGo to next message
Wayne Parham wrote on Fri, 16 November 2018 10:36
Will this happen to the subwoofer even when it is used regularly and used in a normal position? How about when it is used regularly and the positioning is not correct, what will happen to the subwoofer?
Re: Maintaining The Speaker In Good Shape [message #89279 is a reply to message #89274] Wed, 21 November 2018 08:12 Go to previous messageGo to previous message
If the cone is "face down" then it will sag over time, even if used regularly. If the cone faces forward, the suspension will not sag and the driver will last much longer.
Previous Topic: Current Drive
Next Topic: Stop stuttering/skipping
Current Time: Sun Jul 21 13:15:33 CDT 2019
