Home » Audio » Thermionic Emissions » New Project Coming for Diyers who like Triodes
New Project Coming for Diyers who like Triodes [message #88786] Fri, 07 September 2018 16:46 Go to next message
Hi Everyone, I'm in the building process for a class A push-pull triode amp using 6AS7s. Target is 10 watts. It might deliver as much as 14-15 though. I'm waiting on transformers right now. I hope to post the info in about 4-6 weeks. I hear from good sources that the 6AS7 is a really nice tube and makes really nice sounding amps. We shall see. This particular amp is actually a hybrid with a digital front end and remote control. It does have the option to operate directly from a line stage though.
For those of you not familiar with the tube it is a dual triode. Low (under 250) voltage, high current (about 125ma each triode) low gain (2 ugh!) and has a dissipation of 13 watts per triode octal tube. Definitely a different thing for me since most of my designs are running about 450VDC.
Re: New Project Coming for Diyers who like Triodes [message #88787 is a reply to message #88786] Fri, 07 September 2018 17:12 Go to previous messageGo to next message
Wow, Bruce, that's exciting news! Can't wait to see your next post about this new design!
Re: New Project Coming for Diyers who like Triodes [message #88796 is a reply to message #88786] Sat, 08 September 2018 14:13 Go to previous messageGo to next message
Awesome!
So its SRPP....like your other amplifier designs?
I built your mono blocks "kt88's" and they serve as my everyday amps. I've never had anything better for my taste.
All my other amps sit on standby lol.
Re: New Project Coming for Diyers who like Triodes [message #88798 is a reply to message #88796] Sat, 08 September 2018 16:01 Go to previous messageGo to next message
Hi, Yes it does use a SRPP driver. I'm glad you like the KT88 amps. The configuration has proved quite well for over 10 years now. They are not the most powerful amps as all class A U/L amps are pretty inefficient, but IMO they sound far better than many others that have different designs and are seeking more power output.
Re: New Project Coming for Diyers who like Triodes [message #88927 is a reply to message #88798] Tue, 02 October 2018 21:25 Go to previous messageGo to next message
Hi, I hope no one was holding their breath on this one...essentially it is a bust. Yes the concept works....no it doesn't do what is needed. The problem is with the 6AS7 itself. A nice push-pull amp can be made. The problem is drive voltage. One running at 250 B+ with about 50ma per triode needs...get this (from Sveltena) 250 volts peak to peak to deliver about 10 watts. Ouch. They make an audio grade version of the tube BTW. The B+ and current is easy, 250 volts of signal drive isn't. The most logical way I can see doing this is with an interstage trannie. A healthy driver something like maybe a 6V6, EL84 etc with a step up ratio of at least 3 to 1. All in all though it defeats the constant current source in the cathodes and SRPP driver stage. Back to a pretty much conventional design. I have not decided if I want to go that way or not just yet.
Re: New Project Coming for Diyers who like Triodes [message #88928 is a reply to message #88927] Wed, 03 October 2018 09:08 Go to previous messageGo to next message
Gotcha, I understand. I remember your first post said 6AS7 gain was 2x.
Re: New Project Coming for Diyers who like Triodes [message #88934 is a reply to message #88928] Thu, 04 October 2018 16:21 Go to previous message
Hi, I have not given up yet. I just need to rethink the amp.
Previous Topic: Guitar Amp
Next Topic: Western Electric 80th anniversary "300B" tube
Current Time: Wed Jun 26 22:37:43 CDT 2019
