Home » Sponsored » Pi Speakers » 12pi hornsub questions
12pi hornsub questions [message #88484] Sun, 22 July 2018 01:04 Go to next message
noviygera is currently offline  noviygera
Hello,
I'm evaluating the 12pi horns for my application. Home use, 2 channel music. They will need to mate with my mid and high horns.
What's the horn path length?
What would it take to make 12pi play up to 250hz? What part of their geometry makes them roll off above 120hz, as I can see from hornresp simulation?
thanks,
Herman
Re: 12pi hornsub answers [message #88486 is a reply to message #88484] Sun, 22 July 2018 11:16 Go to previous messageGo to next message
The horn path length is 9.3 feet. Upper frequency rolloff is due to mass rolloff, front chamber volume and horn folds. Mass rolloff, front chamber volume and flare are incorporated in the Hornresp model, but the specific folds aren't. That's what tends to make it rolloff a little lower than what the model shows.
Re: 12pi hornsub answers [message #88492 is a reply to message #88486] Tue, 24 July 2018 01:36 Go to previous messageGo to next message
Wayne,
thanks for responding. Possibly in the future, when I build the WE 13a horns, I would be ok with 100hz upper frequency rolloff. I plan to start that project in the near future. However, my current mids play down to 250hz -3db. Out of curiosity and actual current need, what design changes would it take to bring the upper rolloff freq of 12pi to 250hz? Is it possible?
thanks,
Herman
Re: 12pi hornsub answers [message #88496 is a reply to message #88492] Tue, 24 July 2018 08:42 Go to previous message
I think if you could extend the upper cutoff if you unfolded the horn and made it straight.
Previous Topic: Build Thread: 2Pi Towers, 6Pi Corner horns (and possibly a sub and center)
Next Topic: 8pi plan request
Current Time: Sun May 26 09:10:52 CDT 2019
