Home » Audio » Group Build » Red & Green 5 mm LED (Graphs - Uf / If / rD.)
Red & Green 5 mm LED [message #87823] Sun, 15 April 2018 14:04
NOS Siemens LR5360-DG standard diffused 5 mm red LED measured / calculated values (If = 10 mA) :
If = 10 mA, Uf = 1,605 V , rD = 3,54 Ω
index.php?t=getfile&id=2077&private=0
Figure 1: Forward voltage Uf against applied current If for 5 mm red LED LR5360-DG
index.php?t=getfile&id=2078&private=0
Figure 2: Dynamic resistance rD vs. applied current If for 5 mm red LED LR5360-DG
Cheap "no name" 5 mm standard diffused green LED measured / calculated values (If = 10 mA) :
If = 10 mA , Uf = 1,98 V , rD = 10,05 Ω
index.php?t=getfile&id=2079&private=0
Figure 3: Forward voltage Uf against applied current If for green "no name" 5 mm LED
index.php?t=getfile&id=2080&private=0
Figure 4: Dynamic resistance rD vs. applied current for green "no name" 5 mm LED
Measured and calculated values are pretty in line with previously published values for similar LEDs, see for example „Valve Amplifiers 4" by M. Jones, pages 44-45.
  • Attachment: graf4.tif
    (Size: 69.61KB, Downloaded 914 times)
  • Attachment: graf5.tif
    (Size: 39.99KB, Downloaded 902 times)
  • Attachment: graf6.tif
    (Size: 54.72KB, Downloaded 913 times)
  • Attachment: graf7.tif
    (Size: 43.54KB, Downloaded 900 times)
Previous Topic: HLMP-1700 low current 3 mm red LED
Next Topic: Preamp schematic check
Current Time: Tue May 21 20:54:18 CDT 2019
