Home » Audio » Silicon Valley » Amp under desk
Amp under desk [message #87648] Mon, 02 April 2018 20:21 Go to next message
Ouroboros is currently offline  Ouroboros
I've seen some cool looking workstations where people have mounted their amps underneath their desks. Would there be any downsides to doing this? Other than saving space, are there any benefits? I've also read that there should be enough room for airflow between the top of the amp and the desk. How much space do you think is necessary?
Re: Amp under desk [message #87655 is a reply to message #87648] Mon, 02 April 2018 21:29 Go to previous message
Hi That would depend on the amp. If it is a class D one then probably nearly no clearance is needed as they put out little heat. If it is a large class A tube amp...then at least 6 inches all around and IMO I would not put one there in the first place. I have put PCs under the desk on occasion...but with plenty of clearance ...especially around the back where many have fans.
Previous Topic: Crackling
Next Topic: Which is Better, Tube Amps or Solid-State Amps?
Current Time: Thu Jan 17 20:47:58 CST 2019
