Home » Audio » Speaker » Speakers On A Porch
Speakers On A Porch [message #87388] Wed, 07 March 2018 12:26 Go to next message
The porch I have is not enclosed and I live in a semi-rural area. Would you put your speakers on the concrete flooring, or buy smaller ones that you can attach to the corners of the "ceiling"?
Re: Speakers On A Porch [message #87392 is a reply to message #87388] Wed, 07 March 2018 12:57 Go to previous messageGo to next message
Spidey is currently offline  Spidey
Personally, I think I would go with speakers that you can attach to the walls rather than in the ground. I remember reading somewhere that you shouldn't put speakers in corners, but I don't know if that's the case in rooms that aren't enclosed.
Re: Speakers On A Porch [message #87451 is a reply to message #87392] Wed, 14 March 2018 11:41 Go to previous messageGo to next message
Spidey wrote on Wed, 07 March 2018 12:57
I am leaning that way. There seems to be something unproductive about putting speakers on concrete. I like the idea of sound beginning up in the air when you're outside.
Re: Speakers On A Porch [message #87483 is a reply to message #87388] Tue, 20 March 2018 13:16 Go to previous messageGo to next message
Jungle is currently offline  Jungle
I agree, it does seem counterproductive to put them in the ground. I think speakes should always be as close to the level of our ears as possible. How high are your walls?
Re: Speakers On A Porch [message #87524 is a reply to message #87388] Fri, 23 March 2018 20:09 Go to previous message
EParkes is currently offline  EParkes
I agree, Kingfisher. Your sound should be up in the air and that can be difficult when you're putting the speakers on the ground. Do your speakers have some vertical directivity controls?
Previous Topic: Earphones that let me set volume
Next Topic: Concrete speakers
Current Time: Sun Apr 28 20:25:55 CDT 2024
