Home » Audio » Speaker » Bluetooth speakers for home-use
Bluetooth speakers for home-use [message #87152] Mon, 29 January 2018 03:39 Go to next message
Lohan is currently offline  Lohan
Is it a good option to buy Bluetooth speakers for the rooms and spaces in the house that don't have a system? Are the speakers any good or is the audio quality not the same?
Re: Bluetooth speakers for home-use [message #87173 is a reply to message #87152] Wed, 31 January 2018 10:00 Go to previous messageGo to next message
Aria is currently offline  Aria
It's not a bad option. Bluetooth speakers usually aren't equal to wired speakers in terms of sound quality. However, they have their benefits. Portability is a huge one. It also means you could just bring your speaker along with you rather than buying something for each room (unless, of course, you want to). That's just my two cents!
Re: Bluetooth speakers for home-use [message #87175 is a reply to message #87152] Wed, 31 January 2018 11:49 Go to previous message
Kitt is currently offline  Kitt
I agree. The appeal for those kind of speaker lies in their portability. But if sound quality is what you're after, then I don't think that you should go with those.
Previous Topic: Quick Question
Next Topic: Why do speakers fail?
Current Time: Tue Apr 23 03:18:56 CDT 2024
