Home » Audio » Source » Vinyl question
Vinyl question [message #87010] Mon, 15 January 2018 05:17 Go to next message
Tikki is currently offline  Tikki
For those of you in the know, how does dust affect vinyl records and needles? Also, what is the best way to store vinyls to avoid damage in the long term?
Re: Vinyl question [message #87012 is a reply to message #87010] Mon, 15 January 2018 09:27 Go to previous messageGo to next message
Dust particles can damage the vinyl surface by denting it or even becoming embedded in it when struck. So clean the surface of each record with a record cleaning kit before playing it. Store records in their sleeves standing vertically without anything on top of them. Keep them in a room that is temperature and humidity controlled. Never put them in a place that gets very hot or very cold.
Re: Vinyl question [message #87040 is a reply to message #87012] Tue, 16 January 2018 15:13 Go to previous messageGo to next message
A stylus clearner is a good thing as well.
Re: Vinyl question [message #87111 is a reply to message #87012] Mon, 22 January 2018 09:29 Go to previous messageGo to next message
Perfect Storm is currently offline  Perfect Storm
Wayne Parham wrote on Mon, 15 January 2018 09:27
I didn't know that they needed to be stored vertically. Why is that? Also, what kind of sleeves do you recommend? Are the poly sleeves the right way to go?
Re: Vinyl question [message #87115 is a reply to message #87111] Mon, 22 January 2018 10:09 Go to previous messageGo to next message
Records stored horizontally one on top of the other can crush the grooves.
The paper sleeve inside the cardboard cover is useful for storing the record. Don't throw away the sleeve or the cardboard.
Re: Vinyl question [message #87125 is a reply to message #87115] Tue, 23 January 2018 15:10 Go to previous message
Hi, I use MoFi poly sleeves and clear plastic jacket covers. When you care for your records they will last a long time. I was listening to some of mine yesterday that are over 50 years old. In some ways they were made better than many that came later. A lot of ones in the 80s and 90s were poorly made. A real shame as there were a number of really great groups then. With good gear and good care records will out last the owner. Shocked
Previous Topic: Converting cassette tapes to digital format
Next Topic: Rubbing alcohol and records
Current Time: Thu Apr 25 18:13:21 CDT 2024
