Home » Audio » Source » Cartridge alignment in SME 3009 s2 improved - I'm confused!
Cartridge alignment in SME 3009 s2 improved - I'm confused! [message #12285] Tue, 21 June 2005 11:27 Go to next message
Kuja is currently offline  Kuja
Hello,
I just bought a new Shure V15 V cartridge for my SME 3009 s2 improved.
My 3009s2imp is manufactured in April 1976, serial# 212773
I no longer have the original protractor.
I have a question regarding the cartridge alignment null points.
There is a huge confusion on the web regarding this subject!!!
Here are some of the data that I have found in various scanned SME brochures or instruction manuals:
Original 3009 - single null point at 2 2/3 inches (cca 70mm)
3009 II - single null point at 60 mm (I've also found a document mentioning two null points - 60 & 111mm early version,
60 & 115mm later version)
3009 II improved early version - single null point at 60 mm (according to two null points document mentioned earlier -
two points @ 60 & 117mm)
3009 II improved late version - two null points at 66 mm and 121mm
3009R - two null points at 66 mm and 121mm
I didn't know that there are earlier an later versions of 3009 s2 improved.
Which one is mine (April 1976, serial# 212773) ?
What null point settings do you recommend for it?
Thanks in advance,
Aleksandar
PS I also have lost the original 1/16" hexagonal wrench.
Where can I find one? Here, we only have tools based on metric system...
Re: Cartridge alignment in SME 3009 s2 improved - I'm confused! [message #12288 is a reply to message #12285] Tue, 21 June 2005 14:28 Go to previous messageGo to next message
You have to go to the dedicated SME site or The Analog Dept or The Vinyl Zone. They have all that specialised info.
Re: Cartridge alignment in SME 3009 s2 improved - I'm confused! [message #12289 is a reply to message #12288] Tue, 21 June 2005 15:20 Go to previous message
Here's the most important alignment fact I know: with all the protractors it's a best guess as to whether the line to the pivot is on the 2 dimensional point!
Q.E.D. - lining up the stylus and cart on the grids is also a best guess so obsessing over millimeters ain't get you better sound.
Listening will.
Download the Enjoy the Music protractor. It gave me the same results as the mirror one I bought.
Previous Topic: what is "resolution" in sound?
Next Topic: So now I'm even vacuuming!
Current Time: Tue May 14 19:13:15 CDT 2024
