Home » Audio » Group Build » A New Ground
A New Ground [message #86431] Mon, 30 October 2017 12:14 Go to next message
GoldenOldie is currently offline  GoldenOldie
Dedicated ground solutions are not a novel idea but over the past year it seems everyone has been coming out with their version. For a few months I've been thinking about introducing one to my system and had considered Entreq, Telos, Nordost and others. Although I have a bunch of Synergistic Research (SR) kit I had dismissed their older basic ground block as too rinky dink -- however when I heard about the new Active Ground Blocks I thought that could be the way to go. The Active Ground blocks are smallish devices with a mains connection and a plethora of outlets for grounding cables to every component. What do you think is the best?
Re: A New Ground [message #86435 is a reply to message #86431] Mon, 30 October 2017 12:48 Go to previous messageGo to next message
The problem with grounding is pretty basic but the solutions may or may not be. To me, if I can put all equipment close enough together to share a common single-point ground, then that's what I do. But if any part is far away, then the systems need to be isolated rather than trying to connect the grounds. A good ground connection can't have a long conductor separating components because there is a potential voltage drop along the conductor. So the only good way to connect distant equipment is through some method that isolates the systems, e.g. using optical or electro-magnetic couplers.
Re: A New Ground [message #87271 is a reply to message #86435] Sun, 25 February 2018 11:05 Go to previous message
Silver is currently offline  Silver
Wayne Parham wrote on Mon, 30 October 2017 12:48
I was taught that that was a given. Which is why I've never done that. Every component of every system I have ever had were as close together as possible.
Previous Topic: DIY Auto Speakers
Next Topic: Dual Turntable Build
Current Time: Sat Sep 05 06:11:35 CDT 2026
