Home » Audio » Room Acoustics » Total Harmonic Distortion
Total Harmonic Distortion [message #86028] Sun, 03 September 2017 11:39 Go to next message
moss24 is currently offline  moss24
This measures the total amount of distortion from the original audio signal. Does a higher distortion rate mean less quality of the signal?
Re: Total Harmonic Distortion [message #86044 is a reply to message #86028] Mon, 04 September 2017 11:32 Go to previous message
Yes, higher distortion indicates lower quality. Some types of distortion are worse than others though, and THD doesn't show the ratios, only the total amount.
Speakers have a pretty predictable spectrum because of their motor structure. For example, you can assume that the amount of distortion will drop at higher harmonics. But certain configurations tend to reduce even harmonics. So knowing what harmonics are high and what are low gives a better indication of how clear the speaker will sound. Odd harmonics (like 3rd and 5th) sound "grungier" than even harmonics.
Amplifiers tend to generate higher harmonics when they are overdriven, and those are much more objectionable. They are both higher in frequency and higher in amplitude. Tube amps tend to clip a little more gracefully.
Previous Topic: Placing speakers against the wall
Next Topic: What is the best material for a room devoted to music?
Current Time: Wed Apr 24 04:51:43 CDT 2024
