Home » Audio » Source » Sony LX250H BIG Problem
Sony LX250H BIG Problem [message #12093] Fri, 22 April 2005 01:09 Go to next message
bpage is currently offline  bpage
Hey everyone,
My Sony PS-LX250H turntable has a severe problem, well at least very annoying for auto play. When i press the "start" button, the arm moves normally up to the record, lowers the stylus, then plays it... But unusually 2-3
seconds after the stylus has touched the record, the arm just lifts back up again, gets back in its "off" position, and stops the turntable. Could anyone help?
Thanks
Bpage
Re: Sony LX250H BIG Problem [message #12094 is a reply to message #12093] Fri, 22 April 2005 05:07 Go to previous messageGo to next message
Maybe try a different model. These hundred dollar turntables are never very reliable, and you can expect them to chew up your records as well. I suggest discarding it and getting an entry level Technics or Rega turntable at the least.
Re: Sony LX250H BIG Problem [message #12096 is a reply to message #12093] Fri, 22 April 2005 06:36 Go to previous messageGo to next message
Maybe it doesn't like that record?
Re: Sony LX250H BIG Problem [message #12150 is a reply to message #12096] Sun, 08 May 2005 12:54 Go to previous message
Youre right maybe i should try with another turntable... Ive tried with alot of records but thanks for the help anyway.
Thanks.
Bpage
Previous Topic: How much are your records worth?
Next Topic: How does the project rate?
Current Time: Wed May 15 20:57:43 CDT 2024
