Home » Audio » Home Theater » No audio for PC
No audio for PC [message #84482] Sat, 04 February 2017 05:38 Go to next message
moss24 is currently offline  moss24
Is it normal to find home theaters that do not have an audio plug in for the PC? How else can I use the home theater sound on a PC?
Re: No audio for PC [message #84496 is a reply to message #84482] Mon, 06 February 2017 14:33 Go to previous message
You don't need a special plug for PC audio...any spare line level one (aux, tape, cd etc) will do. If you want to directly use something like a USB connection then an adapter will be needed that converts USB to audio. Same goes for optical and similar PC outputs. Most AV gear now has HDMI inputs and now many PCs do as well. That IMO is the best way to connect. Older gear often does not have HDMI capability.
Previous Topic: Cleaning the DVD player
Next Topic: Smart home theater
Current Time: Thu Oct 29 09:25:56 CDT 2026
