Home » Audio » Source » Cool thread on record cleaning
Cool thread on record cleaning [message #11801] Sun, 26 December 2004 02:47 Go to next message
Over at Audiokarma a GPDavis asked if anyone would clean a couple of records on a VPI so he could tell if it was worth buying one. Turned into a cleaner shootout. Results not in yet.
Re: Cool thread on record cleaning [message #11802 is a reply to message #11801] Sun, 26 December 2004 10:38 Go to previous message
That will be interesting. I'll keep an eye on it.
One thing that I guess is a potential problem is the quality of the records being used. If some records are noisy primarily due to surface oil and debris and others are noisy because of groove damage and surface scratches, then obviously the cleaning results will be much different, at no fault of the cleaner. I see that they were planning to do a "before and after" recording, but that won't tell the story as to what caused the noise, damage or debris. Still, I suppose an assumption can be made that the records' surfaces are in fairly equal condition and go from there.
Previous Topic: Pickering TLE stylus
Next Topic: Help on MP3-CD playback?
Current Time: Wed Oct 21 10:42:34 CDT 2026
