Home » xyzzy » Dungeon » Firefox Issues (Technical)
Firefox Issues [message #83135] Sat, 30 July 2016 06:25 Go to next message
Vaiger is currently offline  Vaiger
Is anyone else having issues with Firefox these days, or is it just my system? Slow to load....doesn't want to work 2 tabs at once....and the strangest thing is this: The Homepage won't load, it says there is no internet connection to that, but the bookmarked tabs will as well as sites typed into the search bar. ?? Confused ??
Re: Firefox Issues [message #83162 is a reply to message #83135] Mon, 01 August 2016 05:22 Go to previous messageGo to next message
Azuri is currently offline  Azuri
I'm not having issues with it. I wish the font was bigger though and I wish I could find the setting that can enlarge it.
Re: Firefox Issues [message #83203 is a reply to message #83162] Wed, 03 August 2016 15:58 Go to previous message
Hi, mine works fine. On a given screen type contl + to make everything bigger and ctrl- to make it smaller. Each command can be used more than once to get as big or small as you want. Usually going to a new tab will be back to the normal size. Some however will stay the way you put them. Rolling Eyes
Previous Topic: Meeting Stars
Next Topic: Your Headstone
Current Time: Sat Nov 21 18:27:32 CST 2026
