Home » Audio » Measurement » Sound level meter
Sound level meter [message #82775] Fri, 03 June 2016 03:53 Go to next message
dreamer13 is currently offline  dreamer13
Is sound level meter an absolute tool in measuring audio/noise level? It looks small and simple so it probably can't replace the better system. I've heard that it's also used in noise pollution studies.
Re: Sound level meter [message #82937 is a reply to message #82775] Sun, 26 June 2016 21:37 Go to previous messageGo to next message
The Noise is currently offline  The Noise
There are many different types for different applications, so I would say that yes, a sound level meter can be your ultimate tool.
http://www.bksv.com/Products/handheld-instruments/sound-level-meters/sound-level-meters
This is a professional outfit you might want to try if you're in the market for one. (Or some).
Re: Sound level meter [message #82955 is a reply to message #82937] Tue, 28 June 2016 20:40 Go to previous messageGo to next message
Hi A better option is a calibrated microphone and feed it to a PC with a spectrum analyzer program. many are available and extremely useful in setting up systems in difficult rooms.
Re: Sound level meter [message #85982 is a reply to message #82775] Tue, 29 August 2017 07:47 Go to previous messageGo to next message
I've heard of the sound level meter being used in acoustic measurements. How different are sound level meters from dosimeters? Which one is often preferred over the other?
Re: Sound level meter [message #86378 is a reply to message #82955] Tue, 24 October 2017 12:38 Go to previous messageGo to next message
Zohanna is currently offline  Zohanna
Sounds very educational and interesting. I will definitely try this out. I am always looking for new ways to measure sound. I appreciate your expertise. Thanks.
Re: Sound level meter [message #86490 is a reply to message #82937] Mon, 06 November 2017 16:40 Go to previous messageGo to next message
WorkingWoman2017 is currently offline  WorkingWoman2017
Looks great. Do you happen to know what the cost range is for something like this? I'd rather have a professional piece than others.
Re: Sound level meter [message #99307 is a reply to message #85982] Tue, 24 March 2026 01:09 Go to previous message
George is currently offline  George
lilbill wrote on Tue, 29 August 2017 07:47
Well, I would say that both dosimeters and sound level meters are devices that one can use to measure noise. They are just different tools doing the same job.
Sound level meters are handheld devices that provide a result of how loud a sound gadget is at the moment while it is inside a room. I would say I make use of it when I want to get an instant result. Dosimeter, on the other hand, is a small wearable tool that you can clip on your shoulder while walking around an area with the aim being to measure noise in different parts of the place.
So, in most cases, a lot of people go for dosimeters because it gives a clearer idea of noise measurement across a larger place, unlike what one can do when using sound level meter.
Both do the same work, depending on what you are trying to achieve.
Previous Topic: Acoustitape
Next Topic: Measuring noise
Current Time: Fri Sep 04 17:43:54 CDT 2026
