Home » Audio » Speaker » Do Speakers Matter Much For This?
Do Speakers Matter Much For This? [message #82704] Tue, 24 May 2016 20:34 Go to next message
decibel 12 is currently offline  decibel 12
Talk radio. If you listen to talk radio a lot do you have to be overly concerned about your speaker quality? I can see wanting more bass, but other than that does the quality matter much?
Re: Do Speakers Matter Much For This? [message #82720 is a reply to message #82704] Wed, 25 May 2016 10:24 Go to previous message
Obviously, you need intelligibility. But other than that, if you're only concerned about the vocal range, you don't have to deal with issues that complicate things at low and high frequency. For example, look at the problem of room modes. Those are harder to fix than reflections in the vocal range, which are easily solved with acoustic wedges or pretty much any other absorbant material.
Previous Topic: Best bass sound
Next Topic: Ever heard of AxiomAir Wifi Speakers?
Current Time: Fri Apr 26 12:04:01 CDT 2024
