Home » Audio » Room Acoustics » Open plan acoustic advice
Open plan acoustic advice [message #82585] Thu, 05 May 2016 05:45 Go to next message
BeccaH
Hi all - my boyfriend and I have just moved into our first home together and we want to set up an amazing sound system for music and movies. The problem is that it's open plan - the living room, dining area and kitchen are all one huge space and we haven't the first idea how to plan out where to put speakers to get the best effect. How would you start to tackle this?
Re: Open plan acoustic advice [message #82588 is a reply to message #82585] Thu, 05 May 2016 10:25 Go to previous messageGo to next message
For acoustics, big and open is much better than small and tight.
Re: Open plan acoustic advice [message #82610 is a reply to message #82585] Wed, 11 May 2016 13:30 Go to previous message
BeccaH
So you'd suggest spreading speakers around the whole area and not just in the sitting area where the TV is? Sorry if that's a dumb question but I'm not very technical! I wasn't sure if doing that might cause a lot of echo and reduce the sound quality?
Previous Topic: Bad System For The Space
Next Topic: My living room sounds bad
Current Time: Sat Oct 17 23:08:20 CDT 2026
