Home » Sponsored » Pi Speakers » 4 PI plans, options
4 PI plans, options [message #82548] Mon, 02 May 2016 13:10 Go to next message
xmagellanx is currently offline  xmagellanx
Hi Wayne,
I think I've settled on your 4 PIs for my next build. I have a few questions.
1) Can you share with me the plans for cabinet and XO?
2) Can I use the SEOS 15 waveguide if I go with B&C DE250s?
3) Are reconed JBL 2226h viable?
4) Would you recommend this speaker for classic rock?
Thanks so much in advance.
Greg
Re: 4 PI plans, options [message #82549 is a reply to message #82548] Mon, 02 May 2016 14:33 Go to previous messageGo to next message
Sorry..
Not sure if it matters, but I usually listen at high SPL levels.. My room is 12x16 and partially treated.
Thanks again.
Greg
Re: 4 PI plans, options [message #82571 is a reply to message #82549] Mon, 02 May 2016 18:50 Go to previous message
Answers by numbers:
1. You've got mail!
2. No. The two devices are distinctly different. Please see the H290C waveguide thread for more info.
3. Reconed 2226H are good as new provided the service is done by a qualified technician and the parts are genuine OEM.
4. This speaker is a high-fidelity uniform-directivity loudspeaker, suitable anywhere high quality and high SPL capability are desired. It's good for low-level monitoring or high-level theater applications.
Previous Topic: 3 Pi Subwoofer plan request
Next Topic: Dimensions for the speaker box terminal plate cutout
Current Time: Wed Oct 14 18:48:02 CDT 2026
