Home » Audio » Speaker » What are 'high efficiency' speakers?
What are 'high efficiency' speakers? [message #82100] Mon, 22 February 2016 12:18 Go to next message
Pioneer is currently offline  Pioneer
What are 'high efficiency' speakers and how are they different from regular speakers? Does 'high efficiency' refer to the ratio of electricity used to sound output?
Re: What are 'high efficiency' speakers? [message #82110 is a reply to message #82100] Mon, 22 February 2016 16:22 Go to previous message
Yes. High-efficiency means more electrical energy is converted to acoustic (through kinetic). It almost always means horns are involved, although there are some direct-radiating designs that are more efficient than others.
While efficiency is rated as a percentage, most tend to lump directivity and efficiency together and look at another metric, which is SPL/power/distance. This is a rating of how loud a speaker is at a given distance with a given power level. The most common rating is dBA (20 micropascals) measured at one meter with one watt dissipated. This combines a handful of parameters such as directivity and sensitivity, but it's a useful metric that most people are familiar with.
As a general rule, I'd say low efficiency is anything below 85dB/W/M. Medium is 85dB-90dB, and it's what most speakers are capable of doing. Speakers that can deliver 90-95dB on axis are the low end of the high-efficiency scale. There are some direct-radiating speakers that are in that range. Above 95dB are the highest ratings, and this is generally limited to horns.
Previous Topic: Mounting Ceiling Speakers
Next Topic: Changing over to silver wire
Current Time: Fri Apr 19 10:08:45 CDT 2024
