Home » Audio » Pro Sound » Eliminating Vocals
Eliminating Vocals [message #82079] Sun, 21 February 2016 20:45 Go to next message
Azuri is currently offline  Azuri
Is there technology available that will allow you to eliminate the vocals from a song or CD as it is playing on your stereo? I would like to hear the music only on some of my Pink Floyd CD's.
Re: Eliminating Vocals [message #82252 is a reply to message #82079] Sat, 19 March 2016 08:23 Go to previous message
Yurimi is currently offline  Yurimi
In my opinion, the best choice to remove vocals from songs without instrumental version is using Audacity. Before I knew this software exists, I asked help from a friend to remove the vocals for me. I had no idea what software he used. Although it seems that Audacity cannot completely remove the vocal and may not work on all songs, at least it helps to decrease the vocal volume so you can treat the file as instrumental version.
Previous Topic: Embedded System Question
Next Topic: Digital Recording Question
Current Time: Fri Jan 18 04:43:34 CST 2019
