Home » Audio » Room Acoustics » Wireless surround sound
Wireless surround sound [message #81922] Fri, 29 January 2016 11:21 Go to next message
Lizah is currently offline  Lizah
I am currently looking into a wireless surround sound system for my living room. I don't like how most wired systems limit you to where you can place your speakers. I have a very large room, so I was wondering how far apart these speakers can go? If they go too far will they become out-of-range?
Re: Wireless surround sound [message #82203 is a reply to message #81922] Sun, 13 March 2016 03:06 Go to previous messageGo to next message
Yurimi is currently offline  Yurimi
It seems like around 20 feet is the best distance. Any further than that and the sound may be unbalanced. Other than distance, placement of the speakers is also important. They are usually placed in front of you, forming a triangle, with same distance between all points. They can also be placed to your sides, slightly at the back.
Re: Wireless surround sound [message #83013 is a reply to message #81922] Fri, 15 July 2016 01:24 Go to previous messageGo to next message
Lizah wrote on Fri, 29 January 2016 11:21
I had never thought that there was a limit as to the distance in which the speakers can be placed. This could be the reason that the sound quality in some rooms is usually not that good.
I am also looking to buy a wireless system soon and so this information will really be of help.
Re: Wireless surround sound [message #83776 is a reply to message #81922] Sun, 23 October 2016 09:09 Go to previous messageGo to next message
chatzy02 is currently offline  chatzy02
I spend hundreds of hours over a few months using multiroom wireless speakers in every room and even outside. I have to say we are extremely happy with the results, and I know that you will be too.
Re: Wireless surround sound [message #84162 is a reply to message #83776] Thu, 22 December 2016 06:32 Go to previous message
Odie is currently offline  Odie
We had our first experience with surround sound about a year ago when we wired the TV. The den is 20 feet long and seems to be the perfect setting. 2 speakers beside the TV and 2 at the other end of the room give a theater sound affect. We love it!!
Previous Topic: Best system to use with projector
Next Topic: Reducing noise for drum playing
Current Time: Fri May 03 18:45:32 CDT 2024
