Home » Sponsored » Pi Speakers » 60 x 40 midbass horn...
60 x 40 midbass horn... [message #81577] Sat, 19 September 2015 08:09 Go to next message
Scholl is currently offline  Scholl
Hi guys,
Anyone consider or model a conical midbass horn with 60 deg by 40 deg angles. IT would obviously be longer that what Wayne has worked up. Just looking for 250hz sitting 2-4 foot off the floor in large rooms and mating to a 6040 1" horn on top.
Thanks!!
Scott
Re: 60 x 40 midbass horn... [message #81578 is a reply to message #81577] Sat, 19 September 2015 09:05 Go to previous messageGo to next message
I was working om a midbass horn like that a few years back, but I decided not to follow through with it. Maybe my preliminaries might be useful for you:
Re: 60 x 40 midbass horn... [message #81579 is a reply to message #81578] Sat, 19 September 2015 10:42 Go to previous messageGo to next message
Not bad for a simple build and corner load. I'm looking more for off of the floor. with the same range as your current midhorn but narrower.
Re: 60 x 40 midbass horn... [message #81589 is a reply to message #81579] Wed, 23 September 2015 08:43 Go to previous message
The 9Pi horn was intended for use in freespace, without benefit of boundary loading.
Previous Topic: Hi Wayne, info on 3 Pi sub please
Next Topic: Midhorn Dispersion
Current Time: Tue Apr 23 15:36:24 CDT 2024
