johnnycamp5 Messages: 358 Registered: June 2015 Location: NJ
New guy here .
I'm building a a pair of 4pi's.
I see a lot people build these floor standing speakers with a rearward lean to them.
In other words, the front of the cabinet sits slightly higher than the rear.
Others also put them on stands.
Which should I do?
Can someone tell me why this is?
Why not just put them flat on the floor?
Most people put speakers on stands to position them roughly at ear level. I generally recommend putting mains on stands and flanking them with subs. Study on flanking subs to learn more about that configuration.
The angle of the stands serves to "cradle" the speaker, because there is a back plate (or usually just a lip) that the speaker rests on. It doesn't take much tilt to allow gravity to hold them in place. The stands could be flat though, and the speaker could be secured in a different way.
The pattern is clean above and below the forward centerline +/-20° so some vertical tilt is OK. If the speaker is angled upwards, say 5°, then the vertical nulls would be positioned 25° above and 15° below.
I cannot detect an improvement either by ear or by measurement from adding damping material like putty to the outside of the waveguide. But it doesn't hurt anything either. Some people swear by the stuff and say it reduces bell resonance.
I'm also considering trying a tube amp with these eventually (currently running an Adcom-555).
Any suggestions? Perhaps mono-blocks that don't cost a fortune ?
I think you'll really enjoy that.
I personally own an Audio Note SET amp, an Image SET amp and a Heart Audio UL amp. The Audio Note amp is all tubes, and the other two have tubes in the signal path, but have solid state rectifiers in their power supplies. I use each amp several hours a day.
If you have two good corners, I'd suggest building constant directivity cornerhorns to take advantage of them. They are designed for that placement, and maintain acoustic proximity to the boundaries appropriate for the wavelengths involved. The bass bin and mid horn both work to achieve this goal.
Otherwise, use flanking subs to mitigate the anomalies that invariably arise from placement near boundaries. That's the next best thing, because you cannot get any other kind of speaker acoustically close to the boundaries, and most times, you can't get them far enough away either. So the use of DI-matched waveguide mains with flanking subs are the best option.
