Home » Sponsored » Pi Speakers » 4Pi Crossover Update
4Pi Crossover Update [message #81370] Wed, 03 June 2015 11:33 Go to next message
blvdre is currently offline  blvdre
Hi Wayne
I'm gearing up to build my 4Pi crossovers and am using the H290C horn, the JBL 2226, and the B&C DE250. I remember there being a change to the crossover design to accommodate the new horn, but can't seem to find the specifics through a forum search. Would you mind helping out with this? Thanks very much.
Re: 4Pi Crossover Update [message #81372 is a reply to message #81370] Thu, 04 June 2015 05:49 Go to previous messageGo to next message
Tried a bit more searching on some different strings this morning and found it. Additional of RS, 16 ohms, and removal of C1.
Re: 4Pi Crossover Update [message #81373 is a reply to message #81372] Thu, 04 June 2015 10:13 Go to previous messageGo to next message
That's right! You found it!
Re: 4Pi Crossover Update [message #81377 is a reply to message #81373] Thu, 04 June 2015 11:32 Go to previous message
I'll be placing an order shortly for the x-over PCBs. I've DIY'd enough x-overs to know those boards are a bargain Smile
Previous Topic: Supertweeters?
Next Topic: 4 pi speakers + 3 pi subwoofers, pics & measurements
Current Time: Wed Oct 21 17:19:57 CDT 2026
