Home » Sponsored » Pi Speakers » Starting New Build, a Few Questions...
Starting New Build, a Few Questions... [message #81235] Thu, 23 April 2015 20:45 Go to next message
Jeff V. is currently offline  Jeff V.
I just received my 4pi parts and have a few questions.
Since I'm not using the standard cabinet I'm trying to figure out the displacement of the H290C.
I also picked up the 4pi crossovers. I haven't soldered boards like these, having only worked on through hole boards. Do I lay the components leads on top of the traces and solder away? Thanks!
Here's a pic of my Barzilay 4pi's. They will be a mirrored stereo pair.
index.php?t=getfile&id=1690&private=0
Re: Starting New Build, a Few Questions... [message #81236 is a reply to message #81235] Fri, 24 April 2015 11:08 Go to previous messageGo to next message
The volume displaced by the H290C when mounted in the cabinet is approximately 65 cubic inches.
The crossover has no plate-through holes because I wanted one side to be perfectly flat so it could sit on a gasket and mount directly to the cabinet. Mount the components on the solder side and fasten the coils with a silicon adhesive. It acts as both a mount and a cushion for them. Mount the capacitors and resistors so that they sit a little bit above the board, supported by their leads.
Re: Starting New Build, a Few Questions... [message #81237 is a reply to message #81236] Fri, 24 April 2015 20:15 Go to previous message
Thanks Wayne!
Previous Topic: 4pi Cabinet Port Tuning
Next Topic: B&C DE250
Current Time: Tue Apr 16 18:34:26 CDT 2024
