Home » Audio » Source » AR needle force gauge
AR needle force gauge [message #11545] Sat, 27 March 2004 21:52 Go to next message
Geoff is currently offline  Geoff
I am attempting to set up an old AR turntable model XA Universal model in the correct manner but I do not have a needle force gauge and the arm length adjustment guide. Where can I get these or are there substitutions?
Geoff
Re: AR needle force gauge [message #11547 is a reply to message #11545] Sat, 27 March 2004 22:57 Go to previous messageGo to next message
Howard is currently offline  Howard
Dear Geoff,
I have seen one of these come up on eBay. I will be more than happy to pass on some dimensions for you because it may be possible to make one. I have had a lot of help from J.R. setting up my old XB1. I am sure he might be able to help source one for you.
I would be interested in some pictures of an XA to add to my AR page
Best Wishes
Howard (Queensland)
Re: AR needle force gauge [message #11548 is a reply to message #11545] Sun, 28 March 2004 20:14 Go to previous message
Try Tim At Tim@turntablebasics.com he will have a gauge for a couple bucks that is accurate and universal for setting alignment and for stylus tracking force use the shure gauge again about ten dollars.
Previous Topic: AR XB1 wire ring mod?
Next Topic: new TT from Doc. B
Current Time: Tue Nov 03 10:17:03 CST 2026
