Home » Sponsored » Pi Speakers » Midhorns are back!
Midhorns are back! [message #81030] Sat, 24 January 2015 16:28 Go to next message
Order when ready.
Re: Midhorns are back! [message #81038 is a reply to message #81030] Mon, 26 January 2015 16:27 Go to previous messageGo to next message
Scholl is currently offline  Scholl
Perfect timing, I'm looking at such a project to use with JBL 2118s.
Do you think that's a good combo?
Is pricing for one or two?
Thanks!!
Scott
Re: Midhorns are back! [message #81043 is a reply to message #81038] Tue, 27 January 2015 10:30 Go to previous messageGo to next message
Midhorns are sold individually. I never tested the JBL 2118 on it but I have tested the 2012 and it is perfect; It's one of the drivers recommended in the plans.
Re: Midhorns are back! [message #81045 is a reply to message #81043] Tue, 27 January 2015 17:32 Go to previous messageGo to next message
I guess I'll have to give McBean more time and see what I can come up with for the 2118s. I'd like to experiment with midbass horns once the weather warms up.
Thanks!
Re: Midhorns are back! [message #81581 is a reply to message #81030] Sun, 20 September 2015 02:28 Go to previous messageGo to next message
chrapladm is currently offline  chrapladm
Wayne what is the package size for your midhorn?
I looked at building a mid horn or buying parts from another speaker for the midhorn. Seeing as I live in Australia it makes decisions more difficult. SO I am looking at budget, comparing it to others and going from there.
And do any other 10's work in the horn?
I have a pair of PHL 3451's that I might try in a horn but probably just use them for something else. Better to ask though then to wonder.
Re: Midhorns are back! [message #81591 is a reply to message #81581] Wed, 23 September 2015 08:58 Go to previous message
The midhorn is shipped in a 28" x 16" x 5" container.
Previous Topic: Midhorn Dispersion
Next Topic: JBL 2226H Parameters
Current Time: Thu Oct 15 20:21:06 CDT 2026
