Wayne Parham Messages: 19103 Registered: January 2001
All you need is the H290C waveguides and to make a small change to your crossover. We remove capacitor C1 and add resistor Rs. I'd suggest buying the unstuff PCB we make now to clean things up, not because it's better electrically but because it is a cleaner install than the cable assembly that has R1/R2. The new PCB has locations for those components on it.
The Delta 12LF and PSD2002 drivers you have are still current entry-level offerings, and they sound good. The premium upgrade drivers are the Definimax 4012 midwoofer and the DE250 compression driver, which provide smoother response and reduced distortion.
Thanks Wayne. I all but forgot I had these components in the shop. I might just build them up with the older H290 for now but I will get your PCBs. I think that will make the rebuild feel fresh and tidy things up a bit.
Also, thanks for being here for us and our nagging questions even with all that's going on in your life. I just caught the post about your recent loss and would like to express my condolences. I Hope your holidays are filled with friends and family.
