audioaudio90 Messages: 623 Registered: October 2010
We just rearranged our furniture in the living room and now the surround speaker cables are exposed. It's not a pretty look, but on the other hand I love how open the room looks now. What do you do with exposed cables?
gofar99 Messages: 1903 Registered: May 2010 Location: Southern Arizona
Hi My first thought is to go wireless...but that can cause as many problems as it solves. Some other possibilities are go through the walls to the next room and run the wires there. I have on occasion temporarily removed the base board molding strips and put the wires behind them. You can if desired put mounting plates and jacks where the wires need to come out. It the wires need to be out in open areas them sometimes you can run them under the carpet. A last resort is to use the flat rubber strips for running wires across walkways. They cone in a roll of about 10-12 feet and places like Ace, Home Depot and Lowes usually have them.
We have the same problem in our apartment. We ran the wiring around the perimeter of the room so at least no one will trip on them and the plan now is to buy wire concealment stripping. It looks kind of like quarter round molding but it's hollow on the inside.
