Home » Audio » General » Sound card recommendations
Sound card recommendations [message #80505] Tue, 16 September 2014 23:36 Go to next message
iLoveiPod is currently offline  iLoveiPod
I'm planning on upgrading my sound card so I can hook up a nice set of speakers to my computer. What would others here recommend in the way of the sound card? I will probably go with a set of Logitech speakers.
Re: Sound card recommendations [message #80529 is a reply to message #80505] Thu, 18 September 2014 11:32 Go to previous message
Hi, Logitech speakers are mid-fi at best and the inexpensive ones probably not worth consideration. I believe I would do things the opposite way you plan. Get the best speakers that you can first and see how they sound. You may find that the sound card is fine. For serious use, there are several companies selling sound cards, both internal and external. Figure on somewhere in the ranges of $100 to 250 for a good one.
Previous Topic: Car Stereo
Next Topic: Speaker Phone
Current Time: Tue Nov 17 12:45:49 CST 2026
