Home » Sponsored » Pi Speakers » Start of build (Two questions I would like to pose ?)
Start of build [message #80398] Thu, 04 September 2014 18:12 Go to next message
willsandbills is currently offline  willsandbills
Just started with building three 4 PI cabs and I have two questions that maybe members can advise on
1. have used pocket hole screws plus glue to fix the front, could these pocket holes interfere with performance ? if so should I fill with two pack bonding ??
2. Is it ok to run a bead of silicone around all joints on the inside to help with air tightness ?
willie
Re: Start of build [message #80408 is a reply to message #80398] Fri, 05 September 2014 09:59 Go to previous message
Pocket holes for screws are fine. I've always seen them as a high-quality construction method. Not really needed for loudspeakers, but certainly they don't cause any problems. The screws are really only there to provide clamping force for the glue anyway.
As long as the panels are true, the glue will make a good seal and you don't need anything extra like silicon caulk. That's only necessary on really sloppy builds.
Previous Topic: 3 Pi 4 Pi horn cutout opening
Next Topic: Best surrounds for 4Pi Mains
Current Time: Fri Jul 11 21:33:45 CDT 2025
