Home » xyzzy » Tower » Hulu
Hulu [message #80320] Thu, 28 August 2014 09:39 Go to next message
Have you noticed that Hulu service is going downhill? I think it's buffering more than it used to, even at non-peak times sometimes. It is frustrating.
Re: Hulu [message #80357 is a reply to message #80320] Mon, 01 September 2014 14:35 Go to previous messageGo to next message
I don't know if it's any more frequent than it was before, but I find it annoying too. Sometimes I'd rather just download the episode and watch it so I don't have to worry about buffering delays.
Re: Hulu [message #80368 is a reply to message #80320] Tue, 02 September 2014 15:53 Go to previous messageGo to next message
iLoveiPod is currently offline  iLoveiPod
I've been having issues with Hulu for a long time now, but I thought it was just because I access Hulu through a Roku. A friend uses Hulu through his Xbox One and never has the buffering or freezing problems I have. Weird!
Re: Hulu [message #80374 is a reply to message #80320] Wed, 03 September 2014 08:07 Go to previous messageGo to next message
IloveiPod, does your friend have a different internet service provider or is everything the same otherwise? I don't know why the Xbox would be better than Roku.
Re: Hulu [message #80397 is a reply to message #80374] Thu, 04 September 2014 17:41 Go to previous messageGo to next message
audioaudio90 wrote on Wed, 03 September 2014 08:07
No, everything is the same otherwise. We both use Comcast and both subscribe to the same plan speed-wise. You should see the Hulu app on the Xbox One, though; it's WAY different than it is on the Roku. It looks different, it runs faster, it's more stream-lined, etc. It's like a different app altogether!
Re: Hulu [message #80404 is a reply to message #80320] Fri, 05 September 2014 08:47 Go to previous messageGo to next message
Hmm, how strange that is. Are you going to buy an Xbox just to get the better speed? I don't use an Xbox or Roku myself; we have a smart TV that connects directly to Hulu and Amazon Prime.
Re: Hulu [message #80429 is a reply to message #80404] Sun, 07 September 2014 21:24 Go to previous messageGo to next message
timron is currently offline  timron
audioaudio90 wrote on Fri, 05 September 2014 08:47
I would not suggest this! I have an Xbox One and it's really not all it's cracked up to be. It's not a bad system -- don't get me wrong -- it's just that it's not that much better than a 360. So far I don't feel like it was worth the $500 it cost.
iLoveiPod, maybe look into getting a new Roku if you're not using the most current one that's out there.
Re: Hulu [message #80434 is a reply to message #80429] Mon, 08 September 2014 21:39 Go to previous message
timron wrote on Sun, 07 September 2014 21:24
Thanks, timron. There's no way I could afford a One right now, even with the $100 off/no Kinect deal they have. Getting a new Roku is not a bad idea, though. I think I am using the first version they ever came out with and that wouldn't be too expensive to replace.
Previous Topic: Fitbit "Silent" Alarm
Next Topic: Most Recent Movie?
Current Time: Fri Oct 23 09:44:16 CDT 2026
