Home » Sponsored » Pi Speakers » pi 1 for surround (i would like plans for this speaker if possible :))
pi 1 for surround [message #80262] Mon, 18 August 2014 05:33 Go to next message
im goin to be building new surround speakers and think pi1 is the right choice Smile
if possible i would love plans for them.
bentblaabjerg@yahoo.dk
best regards
bent
Re: pi 1 for surround [message #80263 is a reply to message #80262] Mon, 18 August 2014 08:04 Go to previous messageGo to next message
You've got mail!
Re: pi 1 for surround [message #80269 is a reply to message #80263] Wed, 20 August 2014 12:30 Go to previous messageGo to next message
thanks a lot Smile
i will post pictures after build Smile
panduro
Re: pi 1 for surround [message #80304 is a reply to message #80262] Wed, 27 August 2014 05:20 Go to previous messageGo to next message
Hello guys Smile
so sitting and ordering parts for my pi1 speakers.
crossover calls for a 16ohm 10w resister, but my my preferred parts pusher only has 15 and 18ohm...
will that make a differens or will that be ok? and if so should get 15 or 18 ohm?
best regards
panduro
Re: pi 1 for surround [message #80312 is a reply to message #80304] Wed, 27 August 2014 18:45 Go to previous messageGo to next message
Use 15Ω resistors.
Re: pi 1 for surround [message #80314 is a reply to message #80262] Thu, 28 August 2014 01:27 Go to previous messageGo to next message
hey wayne and thanks for your answer Smile
panduro
Re: pi 1 for surround [message #80337 is a reply to message #80262] Sat, 30 August 2014 09:14 Go to previous messageGo to next message
hello again, so now everything is ordered and I'm itching to make sawdust Smile
i would like to flush mount the drivers but i have not received them yet so i do not know how much i need to remove with my router....
can anybody tell me the dept and distance i need to remove to be able to flush mount them?
best regards
panduro
Re: pi 1 for surround [message #80338 is a reply to message #80337] Sat, 30 August 2014 09:51 Go to previous messageGo to next message
Here are the datasheets, with dimensions:
Re: pi 1 for surround [message #80340 is a reply to message #80262] Sat, 30 August 2014 11:07 Go to previous messageGo to next message
ok thanks again Smile
found the needed measurement for the vita, but not the alpha .
best regards
panduro
Re: pi 1 for surround [message #80347 is a reply to message #80340] Sun, 31 August 2014 07:06 Go to previous messageGo to previous message
It does show the inside baffle cutout and full outside dimension of the Alpha 8, which tells you how wide to cut the recess groove. But you're right, it doesn't show the depth. Make it 3/8".
Previous Topic: Svelte 3pi
Next Topic: The most optimal placement for a single sub
Current Time: Sun Apr 28 09:25:24 CDT 2024
