Re: 7Pi Build 2014 [message #80252 is a reply to message #80113] Sat, 09 August 2014 22:10 Go to previous messageGo to next message
index.php?t=getfile&id=1478&private=0
Mid Cabs are done.
  • Attachment: MidCabs.JPG
    (Size: 93.05KB, Downloaded 8226 times)
Re: 7Pi Build 2014 [message #80253 is a reply to message #80113] Sun, 10 August 2014 16:36 Go to previous messageGo to next message
index.php?t=getfile&id=1484&private=0
index.php?t=getfile&id=1483&private=0
MidCabs in my possession!
index.php?t=getfile&id=1482&private=0
index.php?t=getfile&id=1481&private=0
index.php?t=getfile&id=1480&private=0
Re: 7Pi Build 2014 [message #80254 is a reply to message #80253] Mon, 11 August 2014 08:02 Go to previous messageGo to next message
Those look great!
Re: 7Pi Build 2014 [message #80301 is a reply to message #80254] Tue, 26 August 2014 18:20 Go to previous messageGo to next message
The bass box needs to be sealed up a bit.
I decided on "3M Marine 05220 Fast Cure Adhesive Sealant, White, 3 oz".
Other than that, just doing some sanding and prep for paint.
Decided on Automotive Matte(ish) black. Epoxy primer and two part paint.
Re: 7Pi Build 2014 [message #80332 is a reply to message #80301] Fri, 29 August 2014 17:27 Go to previous messageGo to next message
index.php?t=getfile&id=1512&private=0
Mock up before paint.
  • Attachment: pi7 whole.jpg
    (Size: 892.38KB, Downloaded 7729 times)
Re: 7Pi Build 2014 [message #80334 is a reply to message #80332] Fri, 29 August 2014 19:54 Go to previous messageGo to next message
That's just looking soooo good!
Re: 7Pi Build 2014 [message #80355 is a reply to message #80113] Mon, 01 September 2014 14:01 Go to previous messageGo to next message
First two coats primer in my home made paint booth. I am pulling each piece out one by one for sanding today, then one final coat of primer...
index.php?t=getfile&id=1513&private=0
index.php?t=getfile&id=1514&private=0
index.php?t=getfile&id=1515&private=0
Re: 7Pi Build 2014 [message #80362 is a reply to message #80113] Mon, 01 September 2014 21:44 Go to previous messageGo to next message
All day sanding.. Ready for final primer!
index.php?t=getfile&id=1516&private=0
index.php?t=getfile&id=1517&private=0
index.php?t=getfile&id=1518&private=0
index.php?t=getfile&id=1519&private=0
Re: 7Pi Build 2014 [message #80363 is a reply to message #80362] Tue, 02 September 2014 00:00 Go to previous messageGo to next message
Wow, those look great!
Re: 7Pi Build 2014 [message #80412 is a reply to message #80113] Fri, 05 September 2014 17:56 Go to previous messageGo to previous message
index.php?t=getfile&id=1536&private=0
index.php?t=getfile&id=1535&private=0
Final primer!
index.php?t=getfile&id=1537&private=0
index.php?t=getfile&id=1538&private=0
index.php?t=getfile&id=1539&private=0
Next Topic: Best Amps for 3Pi
Current Time: Tue Apr 23 20:54:34 CDT 2024
