Home » Sponsored » Pi Speakers » 4pi sort of with Jbl 2206h and 2426h
4pi sort of with Jbl 2206h and 2426h [message #80061] Mon, 09 June 2014 19:23 Go to next message
Greg32 is currently offline  Greg32
Hello,
I have these components and im looking for the best way to implement them, I figure that the H290C horn and the 2426H work nicely together with the 4pi crossover but this would need a touch of attenuation to align with the 2206H woofer, any pointers would be greatly appreciated. I understand that the r1 and r2 values need adjusting.
Thank you Greg
Re: 4pi sort of with Jbl 2206h and 2426h [message #80064 is a reply to message #80061] Tue, 10 June 2014 10:58 Go to previous message
The JBL 2426/H290C combination is excellent, and the π crossover is perfectly suited for them. However, the summing and lobe orientation is dependent on the inter-relationship between woofer and tweeter, with the crossover sort of stitching them together. They have to be seen as a matched set, and you probably won't get the best results from using the stock crossover and manipulating just the R1/R2 values to match SPL levels. I would suggest reading the thread below:
Previous Topic: Mid horn flat pack
Next Topic: 2226h on craigslist SAC
Current Time: Sat Nov 07 17:16:38 CST 2026
