Home » Sponsored » Pi Speakers » 7Pi placement in my room
7Pi placement in my room [message #80042] Thu, 05 June 2014 16:52 Go to next message
Nelson Bass
Hi Wayne,
index.php?t=getfile&id=1465&private=0
I'm tempted to build the 7Pi Corner Horns.
But I wonder if the placement in my room will make the 7Pi justice.
I have to place a stereo cabinet on the front wall between the corner horns and a (closed) door near the left speaker is inevitable.
I even dare to put a coffee table in front of my sofa...
What do you think?
Re: 7Pi placement in my room [message #80047 is a reply to message #80042] Fri, 06 June 2014 06:37 Go to previous messageGo to next message
If the closed door doesn't vibrate, that will be fine. But I do worry the door might rattle.
Re: 7Pi placement in my room [message #80057 is a reply to message #80047] Sun, 08 June 2014 06:53 Go to previous messageGo to next message
Nelson Bass
I'll do my best to prevent the door from rattling.
I have seen older 7pi bass horns with a more complex structure around the port so I'm in doubt that I understand your current design right:
index.php?t=getfile&id=1466&private=0
Re: 7Pi placement in my room [message #80060 is a reply to message #80057] Mon, 09 June 2014 10:48 Go to previous messageGo to next message
You've got it right. Older models used a "periscope port" but this "L-shaped port" layout is simpler. Other than that, there is no advantage or disadvantage either way - Both work the same.
Re: 7Pi placement in my room [message #80119 is a reply to message #80060] Sat, 21 June 2014 05:02 Go to previous messageGo to next message
Nelson Bass
Great!
I like to keep things as simple as simple as possible so I changed the bottom panel just to cover the box and removed the panels intended for the corners.
To keep the cabinet sturdy in the corner I added L-shaped profiles to be bolted to the walls.
Go or no go?
https://lh5.googleusercontent.com/-6ayVltU9SIg/U6VOP4h8ubI/AAAAAAAADa8/3fHYKm-q-dM/s907/L-shaped%2520Wall%2520Mount%2520Bracket.png
https://lh5.googleusercontent.com/-urE5e4wwVXo/U6VWE134ecI/AAAAAAAADbc/EZdvyPs8BZI/s361/7Pi%2520Corner%2520Horn.JPG
Re: 7Pi placement in my room [message #80124 is a reply to message #80119] Sat, 21 June 2014 10:01 Go to previous message
That will be fine. Looks great!
Previous Topic: Asymmetrical walls for Pi7
Next Topic: Another pi midhorn question.
Current Time: Thu Apr 18 01:53:18 CDT 2024
