Wayne Parham Messages: 18678 Registered: January 2001
You've got mail!
Kits include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
Bill Epstein Messages: 1088 Registered: May 2009 Location: Smoky Mts. USA
How you build depends on the tools and clamps you have but this is what I do, using braces cut on the same saw setting as the tops and bottoms to square it up. No fasteners, just Titebond and Butt Joints.
I just use dabs of glue to hold the insulation in place but I usually have to "convince" some pieces to stay put with 1/4" staples.
