Home » Sponsored » Pi Speakers » 2 Pi Tower kits (Plans pls)
2 Pi Tower kits [message #79830] Wed, 23 April 2014 19:45 Go to next message
BertW is currently offline  BertW
Difficult to assemble? I have
reasonable woodworking skills.
Is the XO included in the kit?
Re: 2 Pi Tower kits [message #79832 is a reply to message #79830] Thu, 24 April 2014 08:56 Go to previous messageGo to next message
You've got mail!
Kits include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
Re: 2 Pi Tower kits [message #79848 is a reply to message #79830] Fri, 25 April 2014 23:36 Go to previous messageGo to next message
Thanks Wayne
Pdf is my take on the insulation
placement within the towers.
Is the insulation glued in place?
Are the panels butt, rebate, or
biscuit joined?
Regards
Bert
Re: 2 Pi Tower kits [message #79863 is a reply to message #79848] Sat, 26 April 2014 18:25 Go to previous messageGo to next message
How you build depends on the tools and clamps you have but this is what I do, using braces cut on the same saw setting as the tops and bottoms to square it up. No fasteners, just Titebond and Butt Joints.
index.php?t=getfile&id=1459&private=0
I just use dabs of glue to hold the insulation in place but I usually have to "convince" some pieces to stay put with 1/4" staples.
Re: 2 Pi Tower kits [message #79885 is a reply to message #79830] Mon, 28 April 2014 22:06 Go to previous message
Is insulation placed in towers
as illustrated in my drawing?
Previous Topic: 7Pi & 8Pi plans please!
Next Topic: 7 Pi in NorCal?
Current Time: Sun Nov 22 22:51:59 CST 2026
